Hey guys, sadly I can't take pics atm or really describe my situation that well, but on a bus, I had broken the hinge on my ATH-M40X's and in turn the wiring for the cup without the plug ripped and it fell off. Fast track to a year and 3ish months later and I'm gluing the plastic part in the hinge that came off. My question is that I have a red wire and copper wire both exposed so would I just need to twist together the corresponding wires to each color coded counterpart on the wiring by the headband and put some electrical tape on it or would I need to solder it together and use heat shrink?
Rig Specs:
Ryzen 7 1700 3.9ghz @1.33125v Cinebench Scores Best:1750cb Average: 1735cb
Asrock X370 SLI/AC  SOLD
Evga GTX 560 Ti 1gb    Just got a EVGA GTX 780 HydroCopper
G.Skill Ripjaws V 2x8gb 2400mhz oc’d to 2666mhz (bought when ram was still cheap :()
Corsair RM850
Enthoo Pro M Acrylic Changing to a Inwin 301 soon
Custom CPU Loop (watercooling is boring to me right now so I want to go back to air cooling and do like one more WC Loop in a Inwin 301)
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Not So Shitbox v3 Specs:
I7 2600k oc'd to 4.7 @ 1.4ish (will do more when I get a better cooler)
MSI P67-GD55  Sold to fund my gpu
Gigabyte Windforce HD 6950
Team Elite Plus 8gb DDR3 (1 stick) @ 1600mhz
Thermaltake Toughpower 750 watt
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
15in IPS 1080p display
https://linustechtips.com/topic/819920-ath-m40x-fix/
The wires have an enamel coating (the red is the enamel, and the copper wire has a clear enamel over it) so twisting them together will not work - at all. You need to solder and heatshrink them at the very least, if you want them to last at all.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276471
Alright, thank you for the advice.
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276484
No problem.
The most common way to remove enamel is to either burn it off, or scrape it off with sandpaper. Be aware that it will likely be a total pain to solder that wire again, and it might take quite a few tries to get a good, solid connection made.
Hey! New SIgnature!
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276534
1 minute ago, KaminKevCrew said:
No problem.
Would burning it off be like putting the flame of a lighter close to it for a while or would it be easier to just sand it?
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276539
-snip-
This man explains why I used to hate fixing radio mics, would of been nice if performers didn't fuck them up every dam show.
lighter straight onto the wire, and clean up with emery board. solder with moderate to high heat quickly, longer you spend making the joint the more insulation that'll burn up the wires, if you take stupidly long there's a change you'll short them out up the cable pair somewhere.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276547
7 minutes ago, KaminKevCrew said:
Exactly this.
What is emery board and where can I get it?
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276582
Like a nail file board, chemist, drugstore etc. bit of 2500 wet/dry sandpaper works as well.
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276586
Your local drug store: https://www.walgreens.com/store/c/revlon-compact-emery-boards-33100/ID=prod10043-product
Emery cloth is basically just sandpaper that's backed with cloth instead of paper. Emery boards, as far as I've experienced tend to have some kind of foam between the surfaces, but it's basically just sandpaper with some kind of backing that's more durable than paper.
Hey! New SIgnature!
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276587
I have 1000 grit sand paper and I'm on a budget. Would this work fine or do I need to get 2500 grit sandpaper or the emery stuff?
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276593
1000 grit will probably work fine. Just be careful to be gentle, as you might sand right through the wire if you press too hard.
Hey! New SIgnature!
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276600
can't afford a buck?
yea probably, fine grade just gets more crap out of the wire and give a cleaner joint.
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276601
Haha, I just spent all my money buying ryzen and watercooling parts so right now I'm thinking to just use some left over sandpaper I have and use my uncle's soldering iron.
Thank you guys for all the advice.
Rig Specs:
Corsair RM850
Intel 256gb SSD
Kingston 240gb SSD
HyperX 90gb SSD
Cooler Master T4
Enthoo Luxe
Kingston 120gb SSD
WD Black 1tb HDD
Laptop:
Asus GL552VW-DH71
i7 6700HQ
2x8gb DDR4
1tb hard drive
GTX 960m
https://linustechtips.com/topic/819920-ath-m40x-fix/#findComment-10276614
