My last earbuds just broke after serving me for several years. I'm thinking about getting wireless ones mainly to get rid of wire clutter when I'm in the bed.
I don't have a strict budget, but it would be nice if they were around $40.
Quiet Whirl | CPU: AMD Ryzen 7 3700X Cooler: Noctua NH-D15 Mobo: MSI B450 TOMAHAWK MAX RAM: HyperX Fury RGB 32GB (2x16GB) DDR4 3200 Mhz Graphics card: MSI GeForce 3080 GAMING Z TRIO PSU: Corsair RMx Series RM750x Case: Be quiet! Pure Base 600
Buffed HPHP ProBook 430 G4 | CPU: Intel Core i3-7100U RAM: 4GB DDR4 2133Mhz GPU: Intel HD 620 SSD: Some 128GB M.2 SATA
Retired:
Melting plastic | Lenovo IdeaPad Z580 | CPU: Intel Core i7-3630QM RAM: 8GB DDR3 GPU: nVidia GeForce GTX 640M HDD: Western Digital 1TB
The Roaring Beast | CPU: Intel Core i5 4690 (BCLK @ 104MHz = 4,05GHz) Cooler: Akasa X3 Motherboard: Gigabyte GA-Z97-D3H RAM: Kingston 16GB DDR3 (2x8GB) Graphics card: Gigabyte GTX 970 4GB (Core: +130MHz, Mem: +230MHz) SSHD: Seagate 1TB SSD: Samsung 850 Evo 500GB HHD: WD Red 4TB PSU: Fractal Design Essence 500W Case: Zalman Z11 Plus
https://linustechtips.com/topic/818754-wireless-earbuds-around-40/
It really depends what you prefer I personally use the Mee audio x7 plus, they have amazing sound quality and are comfortable and a decent price as well. I know you said your budget is $40 but I would try to increase that a little and you can get a lot more quality for your money, I heard a lot of great things about the Jaybird X3's they are worth considering but they are 80-90 I think
Here's a good resource for wireless earbuds which should help - http://www.flipflopsandapplesauce.com/best-bluetooth-earbuds/
