will these fit?
Solved by Lord Nicoll,
3 minutes ago, titaniumtown said:Will 2 HBT+ Fort A1 fit in a intel s5000psl mobo?
Being a dual LGA771 board, I'm not actually sure, the bracket with the HBT+ Fort A1 looks like the AM type socket mount might be close, but it might need some hacking. It is also possible they might interfere with each other, you'll definitely have to have one pushing hot air into the next one however, but that shouldn't screw up thermals too too bad.
