So I've recently set-up my first build with an old FX-4100. Idle temps are around 43-47 deg. Celsius. When I run Aida64 for 10 mins, load temps go up as high as the mid 70s. AMD lists max temps for this processor on their site at 70.5. I am not overclocking the  chip in any way. I am using a stock cooler. (Previously using a Deepcool gamma archer one which I replaced with the stock since the stock performs better). Is this normal and/or safe? I haven't had any shutdodwns so far despite going over the specified max temp. Should I replace the stock cooler (planning to get one of the Coolermaster Hyper variants), or should I try sticking a case exhaust fan first and see what happens.
*Also, ambient temp here is around 33 deg. Celsius, possibly 36 at noon.
Any help is greatly appreciated.
https://linustechtips.com/topic/818030-fx-4100-high-load-temperature/
Everything clean? Which case?
Temps seem about right since you are living in hot area. If I remember right, 75C is max for FX chips. So getting that in stress test and with stock cooler is about right-ish, all things considered. You won't see those temps in normal use anyway. But I do agree on going for cheap aftermarket cooler, like TX3 Evo or M9a.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
