Current Build
Successful Builds
https://linustechtips.com/topic/817578-nvidia-driver-help/#findComment-10251820
1 minute ago, Hoseiny said:
can you give me link for driver cleaner to setup the new one
i'm using 384.76 with no problems. But I also don't play watchdogs 2.
Here is DDU:
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Current Build
Successful Builds
https://linustechtips.com/topic/817578-nvidia-driver-help/#findComment-10251834
Just now, Hoseiny said:
is it stable with you
as my pc get louder or it's ok ?
what gpu do you have, and how hot is it in your room?
Current Build
Successful Builds
https://linustechtips.com/topic/817578-nvidia-driver-help/#findComment-10251866
gtx 1070
Founder's edition?
Current Build
Successful Builds
https://linustechtips.com/topic/817578-nvidia-driver-help/#findComment-10251872
asus
Your gpu getting louder is normal (just working harder)
Current Build
Successful Builds
https://linustechtips.com/topic/817578-nvidia-driver-help/#findComment-10251876
