i have the msi gaming pro vdh and i accidentaly downloaded the drivers for the msi gaming pro. now whenever i boot the pc it says page fault in non paged area, i did some research and i know what it means and how to fix it. but i cant boot into win 10 in safe mode or anything like that. how do i delete these drivers???
https://linustechtips.com/topic/817375-installed-wrong-drivers-for-mobo-help/
Do you have a driver disk / disk tray you could put it which would hopefully overwrite the previous drivers? I'm not sure if it would be possible to do with a USB but it may be.
PC Specs
i7 6700
Asus H110-PLUS
ASUS STRIX 1070 8GB OC
EVGA G2 550W PSU
3TB HD & 255GB SSD
CiT Galaxy Evolution
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
NZXT S340 ELITE BLACK
i have a disk that contains the drivers, can i install it outside of windows?
If you have a disk drive, give it a go, place it in, start the PC up and hope :)
EDIT: Misread my source. Most likely won't work but perhaps worth a try. Sorry.
PC Specs
i7 6700
Asus H110-PLUS
EVGA G2 550W PSU
3TB HD & 255GB SSD
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
2 minutes ago, chimado said:
i will try it now
If by chance it works, then be sure to update them to the latest as the disk drivers will most likely be outdated.
PC Specs
i7 6700
Asus H110-PLUS
EVGA G2 550W PSU
3TB HD & 255GB SSD
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
What do you have on your windows install? Anything to save?
PC Specs
i7 6700
Asus H110-PLUS
EVGA G2 550W PSU
3TB HD & 255GB SSD
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
Just now, chimado said:
i don't have anything except windows and drivers on the os drive
Is it possible to get access to a PC, plug in and format your hard drive then reinstall?
PC Specs
i7 6700
Asus H110-PLUS
EVGA G2 550W PSU
3TB HD & 255GB SSD
Upgrades
EVGA G2 550W PSU
Asus Strix GTX 1070
