NOTE: Idk if this is in the correct area...
So I am a youtube streamer and I needed to know if these settings are good for my internet speed.
My internet speed is http://www.speedtest.net/result/6509544745.png and my obs settings are, https://i.imgur.com/wh4hI1k.jpg https://i.imgur.com/kutRcXx.jpg and 1920x1080 base and output 60FPS BiCubic 16 samples. I did not put my PC in a perfect situation, its in a normal usage spot no ethernet, no just my device, no closing programs, just normal streaming scenario.
Are these settings okay for playing CS:GO, Rocket League, Minecraft. While having Discord Skype and Chrome running at the same time? If this helps here's my PC specs:
https://linustechtips.com/topic/816871-obs-settings/
Try streaming and see if you can encode it while gaming, we don't know how your laptop will perform without you trying ..
Also, don't record in mov. Annoying format that is probably just renamed MP4..
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244148
 I record with .mov because mp4's corrupt when obs crashes and .mov's don't for me...
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244167
Interesting. I think @AluminiumTech had some issues with OBS too
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244170
Just now, Ryois said:
I streamed and i got perfect ping so..
Try looking at the stream and the dropped frames on OBS, and your FPS. expert bots on dust 2
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244178
FPS 150, dropped frames 10, obs: green square, yt: healthy green
move around in cs , play a death match and see in another computer if the stream is lagging or glitched
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244183
OBS actually warns you about this when you select .mp4.
i also found that .mov is better when skipping back and forth through the recorded video when you watch it with VLC. mp4 gave me a lot of artefacts when i did this
https://linustechtips.com/topic/816871-obs-settings/#findComment-10244772
