Repeater/AP recommendation?
Go to solution Solved by PorkishPig,
3 minutes ago, Morpheus said:
Hey do these have an ethernet input? That way I can just use it in place of the other router I currently have. Thanks again!
They do indeed!
If you would like, you can read up on the capabilities of these two extenders here:
User Guide for AC 750 - http://static.tp-link.com/res/down/doc/RE200(US)_V1_UG.pdf
User Guide for AC 1200 - http://static.tp-link.com/res/down/doc/RE355_V1_UG.pdf
Hey guys. I have a small issue in my house in terms of wifi range. I currently have 2 routers in the house. The main one only covers about half the house with wifi so I have an ethernet cable that runs down to the other side of the house where I have another router to cover the rest of the house. The problem is they have different wifi names and my devices keep disconnecting when I walk around. Can anyone recommend a repeater? that would cover the rest of the house from my main router. Thank you!!
https://linustechtips.com/topic/816706-repeaterap-recommendation/
I would strongly suggest the TP-Link AC1200 (https://smile.amazon.com/dp/B01N8ROH7G) or TP-Link AC750 (https://smile.amazon.com/dp/B00NR2VMNC), depending on how much you are willing to spend. I do not personally use either of these repeaters, as I DIYed a Raspberry Pi repeater, though my friends that have purchased the AC1200 have been more than satisfied with the performance it provides.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
They do indeed!
Desktop
Homelab
Just now, Homeless_Pineapple said:
They do indeed!
Thank you so much :)
