I have bought an Intel Kabylake Pentium G4560, G.skill Ripjaw 8 GB 1866 MHz ram, and an Asus B150 Pro Gaming D3 motherboard. I removed the drivers for the old parts replaced my old processor, ram, and motherboard. Although once I boot it up, it wouldn't post and show anything on the monitor like a new system. I looked at the diagnostic lights whenever I boot it up, and the CPU and ram led lights up. Can someone help me determine the problem?
https://linustechtips.com/topic/816647-pc-wouldnt-post/
Just now, NQSD said:
I was not able to boot it up and update BIOS.
The ram is DDR3.
Does the motherboard support DDR3?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/816647-pc-wouldnt-post/#findComment-10241490
Sounds like you may need to use the old CPU long enough to update the bios to support Kaby Lake.
https://www.asus.com/us/Motherboards/B150-PRO-GAMING-D3/HelpDesk_Download/#
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/816647-pc-wouldnt-post/#findComment-10241493
1 minute ago, NQSD said:
Yes.
Its probably a bios issue
https://linustechtips.com/topic/816647-pc-wouldnt-post/#findComment-10241503
Okay. The CPU part is solved, but what about the ram? I heard that the Pentium processor can support ddr3, but I don't know if it works.
https://linustechtips.com/topic/816647-pc-wouldnt-post/#findComment-10241576
I'm not entirely sure.  https://ark.intel.com/products/97143/Intel-Pentium-Processor-G4560-3M-Cache-3_50-GHz
Says "DDR4-2133/2400, DDR3L-1333/1600 @ 1.35V", not sure if that includes normal DDR3 or not.  Try it and find out, perhaps?
https://linustechtips.com/topic/816647-pc-wouldnt-post/#findComment-10241595
