I recently purchased a TP-Link RE580D wireless extender. Here's how I have everything configured:
Hitron CGN3ACSMR modem from ISP:
-wireless disabled
-DHCP enabled
-LAN IP 192.168.0.1
-subnet mask 255.255.255.0
Netgear R7000 router:
-set to get IP address dynamically
-set to get DNS address automatically
-2.4 GHz band enabled (20/40 MHz coexistence, auto channel)
-5 GHz band enabled (channel 153)
-smart connect enabled (router selects best band for each device, instead of having to connect to a particular band directly)
-DHCP enabled
-LAN IP 192.168.1.1
-192.168.1.2 reserved for RE580D
TP-Link RE580D wireless extender:
-static IP of 192.168.1.2
-default gateway 192.168.1.1
-same SSID and password as the router
-DHCP server off
There was a noticeable improvement based on speed tests and just general usage over the last few weeks. However, my dad just experienced the following issue on his phone:
-"No Internet connection" displayed in orange text
-wireless extender was showing that the phone was connected with an IP address of 192.168.1.13
-phone was showing an IP address of 169.254.1.80
From what I read, this means it couldn't contact the DHCP server (my router). So I decided to move closer to the router and, sure enough, his phone eventually connected.
Is there something that I configured incorrectly? Is there anything I can do to prevent this issue in the future?
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
https://linustechtips.com/topic/816136-help-with-wireless-extender/
