Keyboard Remapping Help
Go to solution Solved by DeDra,
1 hour ago, RadiatingLight said:
not sure TBH.
all keyboards in windows are detected as the same thing.
taran had this problem a while back, maybe watch his vid about his second keyboard (AFAIK he has 4 now) and see how he did it. using lua or something.
I tried following this video, but I ran into a problem; when I input Cyrillic characters into HID Macros (one of the tools Taran used), it refused to recognize it properly, with the character only showing up as a question mark.. However, I tried a program called RightKeyboard, and this one worked! Это хорошо! (excuse my poor Russian; I'm still learning lol)
Link to RightKeyboard https://www.codeproject.com/Articles/20994/Using-multiple-keyboards-with-different-layouts-on
I am looking at remapping one of my keyboards to a Russian (Cyrillic) layout. I've got a Bluetooth keyboard, as well as a usb one at my disposal. As far as the keys themselves go, I'll just tape some pieces of paper with the letters on top (it doesn't need to be fancy). However, the issue lies with my main keyboard, my Razer Blackwidow 2014 that I want to leave untouched in the process. So in short, I want to change the layout of one keyboard to Cyrillic, while keeping the other one in Latin (standard). Any ideas?
Cyrillic layout attached for reference
Edit: I should note that the Blackwidow is going through Razer Synapse if that makes a difference
Comic Sans is the best font.
https://linustechtips.com/topic/815673-keyboard-remapping-help/
1 minute ago, Batteries Included said:
I know you want to keep the Razor keyboard intact, but sometimes you can find keyboard covers for your specific laptop with the right letters. What is the model?
I'm not using a laptop, but rather my main tower. I'm not so much concerned about the physical keys, but rather the software side; what do I need to do to ensure only the one keyboard is remapped?
https://linustechtips.com/topic/815673-keyboard-remapping-help/#findComment-10231205
I don't get it. Just add new language in control panel?
https://linustechtips.com/topic/815673-keyboard-remapping-help/#findComment-10231220
not sure TBH.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/815673-keyboard-remapping-help/#findComment-10231222
he wants one keyboard to be English, and one to be Cyrillic, both at the same time.
Laptop:
https://linustechtips.com/topic/815673-keyboard-remapping-help/#findComment-10231223
not sure TBH.
https://linustechtips.com/topic/815673-keyboard-remapping-help/#findComment-10231451
