Rad Cleaning
Solved by Zyndo,
1 minute ago, That-Something_ said:
I did the can of air there is still some stuck that the air can't get or my finger
then yes. taking the fans off (you don't want those to get wet) and running some water through the fins is a fine way to clean it. I've put water in the tub and swooshed it around a few times and the radiator comes out spotless (give it time to air dry before putting it back into your system).
