Hello I just joined, I saw a video Linus did yesterday and it was talking about bottlenecking. It made me start thinking about weather or not I was bottlenecking my gpu by alot. So I want to see if  overclock could help with that but I don't know how to do it properly exactly. All i know is that i can push my cpu speed to 3.33ghz through the radio and host clock control but now I wonder what some of these other options do like the performance enhance option. Also the pci express option and how I could maximize my performance. Also if you compare ddr3 and ddr2 how much of a difference in performance will that be of course I am not refering to like the highest ddr3 memory vs ddr2s highest but say the average and how that would impact game performace if you run at the same amount of gb's of ram.
CPU intel dual core E5400 overclocked 3.33ghz
Ram ddr2 2gb
GPU 650 ti boost 1gb
Windows 8 64 bit
1368x786
post-46794-0-80296500-1385659689_thumb.j
https://linustechtips.com/topic/81445-e5400-cpu-overclocking-questions/
@Lanoi you got another LGA 775 Pentium user here
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
Raise the fsb as high as you can, while still maintaining stability. You are usually better off with some quality DDR2, maybe 800MHz CL5.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
