Hello there,
my mother uses this external seagate SRD001 drive, but recently it stopped working. We can hear the disc spinning in the external drive but the pc is not recognising the drive.
The fact that the light on the Seagate doesn't turn on should also be noted. Would this be a scratch on the disc or is this another problem? Can we also resolve this problem?
With kind regards,
Ucthar
https://linustechtips.com/topic/814431-seagate-srd001-problem/
If you can hear the disc spinning, but there's no indicator light, then my best guess is that it's only receiving power and not making a data connection.
You could try a different cable, or you could take it apart and try it in a desktop. (Most portable hard drives are just enclosures around a standard 2.5" SATA drive that you can take out and plug into something else.
QUOTE ME IF YOU WANT ME TO REPLY
Le USD $300 Second Hand Potato
CPU: Intel i5-750 @ 3.8GHz Motherboard: Intel DP55WG RAM: 12GB Corsair Budget 1333MHz (2x2GB+2x4GB) GPU: Sapphire Radeon HD 5750 512MB Case: Cooler Master Elite Storage: Seagate Barracuda 500GB PSU: Cooler Master Generic 500W (came with case) Displays: 21.5" 1080p Acer G226HQL Cooling: Cooler Master Hyper 212 Evo Keyboard: Corsair K70 RGB (Mx Reds) Mouse: Logitech G502 Sound: Turtle Beach X12's Operating System: Windows 10
Yep... My peripherals cost me more than the rig itself. ¯\_(ツ)_/¯
https://linustechtips.com/topic/814431-seagate-srd001-problem/#findComment-10217951
