BIOS won't load up! HELP!!!
Solved by BubblyCharizard,
you need to have the 8pin (4+4) eps connector plugged into the motherboard, after that, if you still don't have a post, plug in the speaker that came with the case (or mine at least did) you also can try to use the igpu output from the board to see if that solves It
RipperDoc5456 ·
Posted in Troubleshooting0 -
Nebcs ·
1
FancyPants101 ·
l3eyond ·
1
