This saturday I formatted my system and reinstalled windows 7 Ultimate x64 SP1. After installation I was not facing any problem. But this tuesday I installed Ubuntu GNOME 16.04.2 x64 on another HDD on my system. I have 2 HDDs one for windows and other for LINUX on the same system. But after a day i noticed that the time of Ubuntu is fine but in Windows it lags behind 6 and half hours from the actual time. As the time in Ubuntu is fine then I think its not the CMOS battery's fault. Please help me fixing this. I have to change it everytime when ever I boot into windows. Hope anyone here can help.
https://linustechtips.com/topic/813376-my-windows-clock-problem-help/
3 minutes ago, SCHISCHKA said:
Thanks for your answer.
What I need to do is to change the UTC to LOCAL. But how can I do that? I know very little about linux.
In Linux terminal type:
sudo nano  /etc/adjtime
Change utc to local as in the wiki entry.
press ctrl-x to save & exit.
Boot into windows and correct the time and you should be ok.
ψ ︿_____︿_ψ_
You mean I need to change
0.000000 14602224559 0.000000
1460224559
UTC
to
1460224559
LOCAL
I have to write all these numbers in terminal?
