Storage issue
Go to solution Solved by Guest,
Check if you can find the overwatch game folder, and remove it manually. Might have left some crap. Also check trash can thingy in windows.
So my boot SSD was nearly full, so I went to see what was taking up so much space. It turns out Overwatch was taking 20 GB, so I uninstalled it and rebooted my PC. But now instead of it having ~450 MB of storage left, it has 2.82GB. I was expecting more since I just deleted a 20 GB game. Any ideas on what happened?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/812054-storage-issue/
1 minute ago, TheSneakinSpider said:
the computer may have assigned more data to it because it saw the empty space and filled it because it is faster but I highly doubt that
Still doesn't add up seeing that Overwatch is ~8GB when downloaded :/
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/812054-storage-issue/#findComment-10191454
Just now, TheSneakinSpider said:
maybe only part of overwatch was on the ssd and the rest was put on the hard drive due to lack of space
When I downloaded OW my SSD had enough space
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/812054-storage-issue/#findComment-10191456
Thanks, now I'm re installing on my HDD :D
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/812054-storage-issue/#findComment-10191473
