[Solved] CPU Fan speed error detected
On 7/25/2017 at 8:53 AM, Changis said:if it has a bit of age, it might have seized up while not in use if there has been some kind of gunk buildup over time, though i'm only speculating.. electronics stops working sometimes unfortunately, and sometimes there is no rhyme or reason to why.. atleast not unless you do a deep diagnosis, and even then iv'e encountered issues that makes absolutely no sense, as if the part is just refusing to work out of spite..
i think jayz2¢ said to realistically expect 3-5 years from an AIO
see if you are under warranty still, if not, time for an upgrade.. you could always go with a noctua heatsink as fans are easily replaced, and the heatsink does transport heat away from the cpu even passively and performs about on par with the best aio solutions out there.. though a kilogram of heatsink is huge, and not quite as stylish as a aio(also no RGB *gasp*)
It's merely a few months old. Guess I'll have to RMA, it's still under warrantly luckily.
EDIT: AIO was indeed broken.
