I just upgraded my pc chassis to a thermaltake core x9, and my powersupply from a non-modular psu, to a EVGA G3 bronze. As of installing everything, i pressed the on button, and heard a small crack, when the power button flashes once, as does my led fan, and then nothing. I've disconnected all peripherals, and nothing is working.
I am using a mixture of cablemod cables and the EVGA cables that came in the box, as well as an intel i5 3.2 quad core processor, 1 8GB stick of ddr3 ram, and an asus H81M-Plus motherboard.
If anyone can help, please do!
https://linustechtips.com/topic/810679-help-pc-wont-turn-on/
Im only using the power cable, cpu cable, and sata cables from the psu, could me not using the vga cable cause this? (cause my graphics card doesn't need it).
Oh, and it also smells like a tiny bit of smoke when i try and turn it on, could that mean something?
https://linustechtips.com/topic/810679-help-pc-wont-turn-on/#findComment-10176929
7 minutes ago, LabRat said:
smoke, or the "new" burning off?
is there a little red switch on the back of the power supply, and if there is, what does the number read that's showing?
there isnt a switch or post code display if that's what you're asking. and it smells more like smoke then the "new" burning off
https://linustechtips.com/topic/810679-help-pc-wont-turn-on/#findComment-10177043
