Hello I am new to pc gaming and the max amount of money I have is $450. I was wondering if I can get decent pc with that price. If you could take the time out of your day and see what are the best part for the pc I'll be very thankful. I'm looking to run gtav, arma 3, and csgo thanks for your time
https://linustechtips.com/topic/808514-building-my-first-pc/
For that budget, your best bet is going for the used market as for new components you need a higher budget for a decent experience. Do you have a monitor already? Which resolution?
https://linustechtips.com/topic/808514-building-my-first-pc/#findComment-10153033
I have a moniter and its resolution is 1080p and would $550 make a difference
https://linustechtips.com/topic/808514-building-my-first-pc/#findComment-10153071
for $450, try this:
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($78.89 @ B&H)
Motherboard: Gigabyte - GA-H110M-A Micro ATX LGA1151 Motherboard  ($44.99 @ Newegg)
Memory: Patriot - Viper 4 8GB (1 x 8GB) DDR4-2400 Memory  ($58.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB OC Edition Video Card  ($143.77 @ Amazon)
Case: DIYPC - MA01-R MicroATX Mini Tower Case  ($21.98 @ Newegg)
Power Supply: SeaSonic - S12II 430W 80+ Bronze Certified ATX Power Supply  ($31.98 @ Newegg)
Total: $428.48
Generated by PCPartPicker 2017-07-17 02:13 EDT-0400
https://linustechtips.com/topic/808514-building-my-first-pc/#findComment-10153117
4 minutes ago, herman mcpootis said:
for $450, try this:
Total: $428.48
Ok thanks for your time
https://linustechtips.com/topic/808514-building-my-first-pc/#findComment-10153132
