It launches in the background but doesn't ever show up
and it uses 28%- 40% of my cpu
I have  uninstalled and reinstalled 3 times...
 I have used task manager to end the process every time...
Rebooted my pc about 20 times...
PLEASE HELP ME
My PC Specs: CPU: Core i5 4590 @ stock speeds, GPU: RX 480 8GB, RAM: 16GB DDR3 @1600mhz
Case: Zalman ZM-T4,Motherboard: GigaByte GA-H81M-S2H LGA 1150, HDD/SSD: 2TB Seagate Expansion drive, 1TB Samsung Portable HDD, 160gb Intel SSD, PSU: 550w corsair cxm
:lol:  :lol:  :lol:  :lol:  :lol:  :lol:
https://linustechtips.com/topic/808446-steam-will-not-open-please-help/
Can you go to the task bar, far right corner, and find it's icon and double click it? It should open it.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
it doesn't show up there :(
Hmmm. When you uninstall it, is there any option to remove config files and such?
Mouse: EVGA X17
1. Try scanning your pc for a virus
2. Compatibility Mode for Windows 8 or 7.
3. Run as Administrator?
Main Rig Specs:
CPU - I5-2500k 3.4 - 4.0 GHz
MOBO - ASUS PBZ77-V LK
RAM - 8GB DDR3 GSKill Ripjaws
GPU - GTX 780ti
PSU - 600B PSU EVGA
Case - Bitfenix Merc Beta
Cooler - Be Quiet! Pure Rock Slim
no, it just uninstalls everything in the steam file
Done all 3
none worked
Just now, RGProductions said:
If all else fails, just reinstall windows
It fixes all software issues doing that
ugh....that'd make my day even worse
Try this
https://steamcommunity.com/discussions/forum/1/864970668173450825/
Otherwise what RGProductions said is right, just go ahead and reinstall windows.
Main Rig Specs:
GPU - GTX 780ti
PSU - 600B PSU EVGA
Then find the steam folder in your app files, and delete it, and any other vestiges of Steam you can find. Then use CCleaner to back up and clean the registry.
Mouse: EVGA X17
I have done that already :(
there's no Client Registry file :(
You've reinstalled steam right? It should be there.
Main Rig Specs:
GPU - GTX 780ti
PSU - 600B PSU EVGA
it isn't there..... would it be in the main steam folder?
C:\Program Files (x86)\Steam is the directory I found it in.
Main Rig Specs:
GPU - GTX 780ti
PSU - 600B PSU EVGA
hmmm.... I'm going to copy my steam install from another PC over to this PC (which has the clientregistry folder :) )
Open Task Manager. Ctrl + Shift + Esc
Go to processes.
Press "s".
Find any Steam services and end them, preferably behind the barn so the kids don't see.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Also, out of curiousity, are you using multiple panels or have you tried Shift + Win + Left/Right Arrow?
Go to processes.
Press "s".
I've already done that....
and
WHUT
I've reinstalled windows
PLEASE KILL ME
