Hi
Am looking at building a new PC for around ~2000 dollars $AUD (including a monitor).
I mainly do a little gaming, 3d modeling/rendering as well as programming.
Build that I am looking at, it linked below,
https://pcpartpicker.com/list/phfbgL
The current ram I am looking at is Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200
I would just like to make sure that it is compatible with the build. On Corsair's website, it isn't listed under the ryzen compatible memory section, but in the motherboard(MSI - X370 GAMING PRO CARBON) specifications, it says it is compatible??
Thanks in advance :)
https://linustechtips.com/topic/807565-build-plan-questions/
Hey,
Often PC Part Picker will tell you if items are not compatible and if there is a problem it is highly likely that you would be able to return it. Could I ask as to why you want Win 10 Pro as you could save some money on that and then spend said money on a different GPU with a greater amount of CUDA cores, therefore helping in your rendering applications, provided they support this.
Hope this helps,
TT
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143621
What programs do you use for 3D modeling and rendering?
11 minutes ago, Zigon said:
Hello
Was looking at windows 10 pro for the virtualization side of things and BitLocker
Just as a note, you might want to quote people in the future, or they might not know you replied! :)
20 minutes ago, TurtleTrain said:
Hey,
Hope this helps,
TT
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143691
Hey,
That is fair enough, however, I would recommend that if you have Pro on another device, you could encrypt them from there, you could also use other encryption services, for example, sandisk have their own system and so you could use something like that, you could also use something like a cloud storage.
In terms of virtualization, I don't know much about that, however I would think the better card will help you more than this due to the extra cores.
Hope this helps,
TT
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143698
5 minutes ago, Zigon said:
Mainly blender for now, so GPUs can be fully utilized
Oh ok, I was mainly asking since a lot of 3D modeling apps are quite single threaded so Ryzen might not be the best choice but if it's blender Ryzen is definitely the best choice.
If that's the case my only suggestion is maybe get a different psu. This one is cheaper and better than the one you had. Everything else looks great.
https://pcpartpicker.com/product/PVzZxr/corsair-txm-gold-650w-80-gold-certified-semi-modular-atx-power-supply-cp-9020132-na
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143726
Unfortunately, my normal PC parts supplier doesn't stock that psu. One other supplier does have it but the cost is much greater.
Also as I am in Australia, if I was to get it from Amazon or NewEgg, the shipping cost negates any savings
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143766
In that case, I have zero suggestions :P
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143778
1 hour ago, Zigon said:
Hi
Corsair is not very good at maintaining memory QVL lists. Fortunately MSI keeps good lists. Since the memory, CMK16GX4M2B3200C16, is on the motherboard's memory QVL you can feel confident that the kit will work. Note though that the motherboard currently only supports these modules in two DIMM slots. This means that any memory upgrade will require replacing the memory, not simply adding a second kit.
Unless there are features in Windows 10 Pro that you need, (e.g. Bitlocker), you will be fine with the standard version. However, the Windows 10 OEM license does not allow use in DIY builds. Windows 10 Home (32/64-bit) is the correct version for DIY builds.
https://linustechtips.com/topic/807565-build-plan-questions/#findComment-10143992
