ARMA 3 doesn't exactly run "great" on anything, but you should be aiming for a CPU with high single-threaded performance. I'd recommend a i7-7700K and fast DDR4 memory.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10135906
2 minutes ago, ewenjo said:
Is Corsair Vengeance LPX DDR4 3000MHz 2x8GB good enought ram?
It's good. But, eh, not what I'd pick if I had an "unlimited budget".
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10135927
1 minute ago, ewenjo said:
What do you recommend?
You're going to be CPU-bottlenecked in ARMA 3... so if you have a generous budget, I'd get a 16GB kit of 3600MHz TridentZs.
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10135946
5 minutes ago, ewenjo said:
Ok, thank you for your time. The corsair ram was just something I had laying around so.
Oh, if you have the RAM already, I'd just use it. No need to buy another kit.
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10136000
http://techreport.com/review/31179/intel-core-i7-7700k-kaby-lake-cpu-reviewed/11
Arma III loves fast memory. I'd say 3000–3200 MHz at least, and if you can overclock beyond that, it still appears to help.
I don't think any CPU out there is going to do any better than an overclocked 7700K in this game, if it's as reliant on individual thread performance as it sounds.
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10136015
I will try with the ram I've got now with a i7 7700k and upgrade if It's not good enough :)
https://linustechtips.com/topic/806873-best-cpu-for-arma-3/#findComment-10136035
