plaz help
Solved by PeachyUwUSenpai,
your gpu is quite old also thats how gpus tend to act
2 minutes ago, Janner558 said:Probably a better graphics card, because at the moment it's pegged at a 100% thus bottle necking the cpu. You could try dropping the resolution to reduce the gpu work load.
in pretty much all computers the gpu is always the bottleneck no point in bringing that up. the issue is he's running an old gpu it's just a bad gpu for games like arma .
