22 minutes ago, de^N GAMDOM.COM said:
I don't know if GPU Fan slowly spinning is GPU's fault or PSU's?
So could it be GPU's fault? gpu is 6 years old it'll prob die soon
So what's the question? Give us some more details to look into, maybe we could help you.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/806089-gpu-fan-help/#findComment-10127363
39 minutes ago, de^N GAMDOM.COM said:
It usually reaches 105c when playing games and 80c when im idle, so im asking if fan spinning slowly if it could be GPUs fault, if lifespan is important gpu is old like 5 years.
Have you try cleaning your fans? Maybe too much dusts are stopping the fans from spinning.
https://linustechtips.com/topic/806089-gpu-fan-help/#findComment-10129317
It's probably the fan failing. Many graphics cards use fairly cheap fans that are prone to failing in that kind of timeframe given the stress and heat, especially with heavier use but even without that.
It could also be software related (though how that would happen without an intentionally bad fan curve is relatively hard to imagine). A gunked-up, physically impeded fan is another possibility generally but you say that's not the case.
It's almost certainly not the power supply unit of the computer. In theory it could possibly be the power circuitry on the graphics card itself or the control circuit for however the fan is hooked up (probably just direct voltage control). It's almost certainly not the GPU chip itself.
https://linustechtips.com/topic/806089-gpu-fan-help/#findComment-10129420
Last year my stock fan died i bought a new fan and it seems everytime i buy a new one fan it either dies or stops spinning fast.
https://linustechtips.com/topic/806089-gpu-fan-help/#findComment-10129429
You replaced the fan on the graphics card itself? With what? Which graphics card model? Picture/what does it look like? What fan are you using?
https://linustechtips.com/topic/806089-gpu-fan-help/#findComment-10129432
