Just now, GutoGordo said:
Just read at Nvidia site but I kinda remember you will need just around 550W PSU and a 6pin cable
they always over-estimate though, just so they can't be blamed if someone uses a psu too low.
Realistically you could run that system on a 350 watt psu, but it'd be cutting it very close.
https://linustechtips.com/topic/805853-power-supply/#findComment-10125172
1 hour ago, Glimpse said:
My friend is doing a build with a 1060 6gb and a 1600x and he wants to know if he should get the EVGA SuperNova g2 650w or 750w.
The system as outlined draws less than 350W.
Corsair CX450MSeaSonic M12II 520 BronzeSeaSonic SSR-450RMSeaSonic SSR-550RMSeaSonic FOCUS Plus 550 Gold, and EVGA SuperNOVA G3 G550 are all pretty good. The G3 is probably the best of the lot.
https://linustechtips.com/topic/805853-power-supply/#findComment-10125366
