Good day guys. I hope someone can help me.
I have built a PC and it seems to work fine after using it for the first time but the next day I can't turn it on using the case switch. I played with the PSU switches and unplugged then plugged it from the main power line. It turned on but it turned off after a few minutes. Sometimes I'm able to use it for hours but after shutting it down, the same problem occurs the next time I use it. Basically, I just rely on playing with the switches and luck to see if I can use it for hours.
I made a thread about this issue months ago but haven't really resolved it because I was working away from my hometown for these past months. I just got home last weekend so I got the chance to try new things to troubleshoot this.
Here are the additional things that I already did to troubleshoot this. I unplugged the case POWER and RESET switches from the front panel and checked the continuity using a multimeter and they both work fine (pressing it creates a momentary contact). Next, I tried the screwdriver trick (shorting the power pins with a screwdriver) to start the motherboard but it won't boot. Then finally I checked the continuity of the power pins and found out that they are connected, I don't really know if it should really be that way but after I checked the pin outs of the motherboard it seems that one of the two power/reset pins is connected to ground so does that mean that the other pin is grounded? Is my motherboard already dead?
Thanks in advance for your response.
https://linustechtips.com/topic/805684-pc-startup-issues-help/
night theme fixed.
check your CPU temps (bios/windows) and your gpu temps, and if you feel adventerous feel the motherboard heatsinks and see if they're warm. the ones near the cpu should be warm/hot to touch and the ones near the bottom left should be warm aswell
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/805684-pc-startup-issues-help/#findComment-10123219
1 minute ago, themctipers said:
night theme fixed.
Actually I already checked that. CPU Temperatures seem to be stable when I'm able to use it for hours (~30-35C idle and ~50-60C when playing). Heatsinks are warm to touch as well.
https://linustechtips.com/topic/805684-pc-startup-issues-help/#findComment-10123250
 rma motherboard
https://linustechtips.com/topic/805684-pc-startup-issues-help/#findComment-10123255
