Right I'll dive straight into the problem. I recently just build a rig using intel's i5 3570k and a ASrock Z77 extreme 4. I wanted to start overlcocking when I noticed that at idle with all programs closed the CPU idles at 3600MHz. I've only seen suggestions that I use the 'balanced' power plan instead of 'high performance'. However my cpu still idles at 3600MHz with 'balanced' and will only go down to 1600MHz when I use 'power saver'. I changed the advanced settings of both 'balanced' and 'power saver' to be exactly the same yet my cpu still idles at 3600MHz when 'balanced' is selected. I have made sure my speedstep is indeed enabled in the BIOS and quite frankly I don't know what else to do besides a clean install of windows and checking CPU-Z in between every driver install to find the culprit if a software is to be blamed. Any ideas?
https://linustechtips.com/topic/805-problem-cpu-idles-at-maximum-speed/
Well, are you using Auto voltage in your bios, or are you using a fixed voltage that you set yourself?
Whenever i set the voltage on my CPU to anything else than auto, I always have a static clock frequency. However if I have the voltage set to 'auto'
I get a more flexible, or dynamic clock frequency. (1.6Ghz - 3.5Ghz).depending on the load put on the system of course.
An opinion far away from your own can only be seen as madness.
pictures of the bios maybe (just use a camera) and i, and i suspect others would like to see screenshots of the temperature and a cpu-z summary link. it is hard to advise without seeing the problem, unless you have encountered the same issue before, all you can do is guess without seeing it. so pictures of your bios setup, your cpu temp (and active speed if you use a program like core temp) and the cpu-z online summary can help.
where you doing something in the background when in cpu-z...???? like youtube or something?? if not speed step could be the only culprit......why don't you try clear CMOS.
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
Pictures of BIOS would help, however you can also try to clear your CMOS which resets your BIOS to default. You can do this a couple ways: If your board has a CLR_CMS jumper near the bottom right ( could be bottom left ) of the board, find something to short that connection out; a flathead screwdriver is a good option. The other method, and probably easier, is to remove the battery. It's round and fairly obvious, simply push in the metal tab and pop the battery out. Leave it out for up to 1 minute, then put it back in.
Thanks guys, I appreciate the input. So far you guys have been more helpful than ocn : D
Here are 2 screenshots of CPU-Z and the temps. Nothing besides drivers were running in the background
Power%20saver.png?w=5dc15d37
I wasn't quite sure what to take in the bios so I only snapped a few regarding the CPU. I hope its readable
Maybe I will just load BIOS defaults seeing how I don't remember changing anything in the BIOS in the first place
  • 9 years later...
