I mostly play League of Legends and Overwatch. I also record and do video editing. Budget is $500. My friends are planning to play games that I believe would toast my PC. Not sure if this is worth noting but sometimes my PC gets hot really fast, I want reduce that heat if possible... Here are my specs:
Motherboard: MSI 970A - G43
CPU: AMD FX-6300 & Stock Cooler
Memory: 2x4GB Corsair Vengeance
Storage: WD 10ezex 1TB
GPU: NVIDIA GTX 750 TI
PSU: LEPA MC 600W
P.S. I bought this from a friend somewhere in December of 2015 for $400 and have been using it since then.
https://linustechtips.com/topic/804143-help-with-pc-upgrade/
PSU: LEPA MC 600W
go for Ryzen, upgrade the mobo, and get some more RAM (probably 8 GB more)
https://linustechtips.com/topic/804143-help-with-pc-upgrade/#findComment-10109132
