hi. My problem is that when i start up my PC asus fan expert 4 puts the fans at 100% and i have to manually enter in setings and select silence mode. Does anyone know how to fix it? Thanks. Also sometimes with certain games AISuite looses controll of one of my extension fans and puts it at 100% also, but the fix here is restart.
https://linustechtips.com/topic/803294-fan-expert-4/
Did you update the software? ASUS Update software is garbage so you have to do it manually.
Also check your BIOS settings for your fan control and also make sure in the ASUS software they're correctly picked as PWM or not.
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
https://linustechtips.com/topic/803294-fan-expert-4/#findComment-10098487
