I just got a 144hz 1080p monitor and am absolutely loving it. So many headshots lol. One thing I noticed is that my temperatures have increased fairly significantly while gaming to about 70C on the 7700k and 80C on the GTX 1070. I think I'm going to delid the CPU. Just wondering if such a temperature increase is typical when upgrading to a higher refresh rate monitor?
https://linustechtips.com/topic/803263-does-going-144hz-affect-temps/
No, it just provides video signal, monitor is separate in terms of how many frames it can display (Unless you had VSync on before, that would limit it).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
I believe I did have vsync or some form of FPS limitation on before
It shouldnt affect the system, its probably the fact that its summer and its thus hot outside and in.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
if you have your fps for example locked at 60 and you buy a bigger faster screen maybe your gpu will need to work a litle harder to stay on the same fps and as result it might increase the gpu's temps (i did not test this this is just how i think it would work)
Vsync or whatever you had most likely limited it to 60fps, which in most games a 1070 can do easily, now you're running 144hz though the 1070 is having to work harder and will most likely be at 100% usage to get to, or as close as it can to 144fps, depending on the game and settings.
