Im going to cram a system into an old Xbox 360 case, and i need a PCI-E riser to lay the GPU on its side to fit. Any suggestions for one? It preferably would be very short, as it doesnt need to be too far from the mobo.
https://linustechtips.com/topic/802918-pci-e-riser-choice/
Look for PCIe riser on your choice of online shopping and find the shortest
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/802918-pci-e-riser-choice/#findComment-10094098
