So I had freezing problems with my rx 460 2 gb and came to the conclusion that the problem is with the drivers and I needed to underclock it from the Wattman and everything was ok.. Only problem is that in some time period for some reason these settings reset by themselves to the default ones and while I am playing it crashes. How do I fix that?
https://linustechtips.com/topic/802707-rx-460-help/
