I know my old Phenom works and I got all of my stuff for my PC and no boot even with my old Phenom nothing visible is wrong with the new mobo I know the PSU, GPU work I just tested it and I have a RMA all ready to go with my Asus mobo and with my old Phenom I can go into the bios and everything only thing wrong with it is IMC is dead I've tested everything possible and nothing and I am really confused why it isn't working and fans go to 100% on the new mobo and CPU heats up as normal, and no signal what so ever with the Asus mobo and my specs are in my signature
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/802375-mobo-issues/
You just broke a record. 2 punctuation for all that text.
Would you be able to restructure your post a bit better to help us get a sense of what is going on? I'm not trying to be insulting, but this was very difficult to read/understand at all.
||Intel i7-7770k | MSi Z270 Carbon Gaming Pro | 16GB G.Skill TridentZ RGB 3000mhz | EVGA GTX 1080 FTW | Corsair 400C & RM750 PSU + H100i||
||Creative SB Recon 3D Fatal1ty | Samsung Evo 850 500GB | Seagate 2TB | Lots of red LED fans |Corsair K70 Black | Razer Deathadder Chroma||
||Dell 27" U2713HM | ASUS VP239H | Kingston HyperX Cloud II | Win 10 Pro | Portable gaming made possible with MSI GT70 2OC and a bag to dump in||
~~Assembled with love and care~~
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10091951
I cant do anything with it no output only power to CPU, mobo, GPU, fans, I get nothing with my keyboard, I dont get any signal at all (GPU and Igpu) doesnt work with any of my AM3 or AM3+ cpus
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10091969
Alright. If you can test your mobo with no ram (if you have a pc speaker hooked up) and it does not beep, then you're looking at a dead motherboard. If asus has an RMA # created for you though, they probably suspect that its dead. I'd just ship it out and get it replaced.
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10091987
I have the RMA label on the box and mobo inside and its in the boxed sealed and I tested with no ram, no GPU, and I dont have a internal speaker and I've heard stories from people and they said stay away from Asus' customer service, and I have the RMA with Newegg.ca
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10092020
I have RMA'ed with ASUS many times and have had 0 issues. Only had issues with their Video card RMA department. Motherboards I've replaced are usualy back within two weeks. Which is pretty good in my experience.
PS: Everyone has at least a negative opinion about every manufacturer. Ignore them and go with your experience and what you "know" is factual, not what people say.
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10092031
Well I got everything with newegg
https://linustechtips.com/topic/802375-mobo-issues/#findComment-10093106
