Case Fans
Go to solution Solved by Gamerguy207,
Leave it I have the same case although looking at the picture you might want to move your top fan over one because then it won't fight for air with that rear mounted fan
I recently built my computer and bought 5 case fans to go with it. I have a corsair carbide spec-01 case with 2 intakes in the front and 2 exhausts in the top and back. I read on forums that you should cover your holes and that too many exhaust fans was bad. I was wondering if I should cover the fan hole, leave it empty, or install another fan.
Thanks,
cam
https://linustechtips.com/topic/802354-case-fans/
