I think it just lowers the brightness and disables background apps and such. IDK how much it effects battery life though.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Just now, basedthirst said:
Hell I'll probably just leave it on then
Yeah, if you notice slowdowns in games or other intensive programs, it only takes 5 seconds to turn it off.
Mouse: EVGA X17
1 hour ago, basedthirst said:
Is it worth turning on? Will it actually make a difference in battery life and how much will it affect normal performance?
To be clear, you have Power Saver power plan and you have Battery Saver under Windows 10 (assuming your not a Windows Insider, as that changed).
The power plans (High performance, Balance, Power Saver) are in the path to be discontinued. What the plans do is what they are defined to do under the advanced panel, which is mostly reduce screen brightness, limit CPU clock, and limit other things. It doesn't stop services and tasks.
Battery Saver limits background programs, stops live tiles from working, stop indexing, and a few other things, and reduce screen brightness.
In the Fall Creator Update coming in Sept/Oct of this year (expected), you have this:
Where, depending on the slider position will even even disable transparency effect and other effect, including system performance and be more useful.
What's the ideal settings on a desktop system or mobile system plugged in: Balance (or mid option in the slider panel pictured above).
Balance allows power saving features to kick in, but give you all the performance you need. High Performance, disables power saving features, creating more system heat and noise. This in turn, for mobile systems, "disables" Turbo boost, as the CPU is too hot for the CPU to be able to clock faster.. I guess maybe if you laptop has a beefy cooling solution it might affect you less, where it will still be able to turbo boost but for less time. On a desktop, it is not a problem, but you are consuming power for nothing, an d your system makes more noise due to the additional heat produced.
