hi guys
so in a nutshell i have installed a fresh windows 10 x64 and when i try updating graphic drivers for my amd r9 270x the pc screen switches off and on then is just blank,
i have tryed DDU many times and even differant or older drivers from the amd website. i have gone into device manager and tryed from there as well but in seconds after clicking to
do the driver update crashes again.
now i can use the pc just fine with no display adaptors but yeh thats not want we want.
pc specs
PSU 750w
ASUS h61m-k mobo
kingston 8 gig ram
Intel core I5 - 3330
Asus R9 270x GPU
please guys i am not very tech savvy, i am mechanical so any info or help would be greatly appreciated
https://linustechtips.com/topic/801697-r9-270x-problems/
2 minutes ago, hooligan said:
hi guys
pc specs
PSU 750w
ASUS h61m-k mobo
kingston 8 gig ram
Asus R9 270x GPU
try installing windows fresh with a new iso
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/801697-r9-270x-problems/#findComment-10081088
Make sure you're not installing the BETA Drivers, as I did that last week for my streaming pc connected to my tv and it kept flashing black and white. I uninstalled all the AMD drivers and searched drivers from a month ago and everything worked fine.
Hope that helps buddy!
https://linustechtips.com/topic/801697-r9-270x-problems/#findComment-10081118
so just an update for you guys. i had a old HD5750 lying around so i installed it with drivers and works perfectly
although i cant run at 1080p anymore it should last till i can aquire a better GPU. just weird how the R9 270x kept crashing as im installing the drivers. i have tryed the whole day downloading differant driver for the stupid GPU but yeh i am almost certain its the card that has tanked in some way
anyway thanks for all the help appreciate it.
https://linustechtips.com/topic/801697-r9-270x-problems/#findComment-10085113
