Im looking for a low profile usb hub 7 (atleast) ports. Not for charging but I think it would need to have it's own power.
I have a spertate 6 port charging station this is strickly a usb hub for using usb devices like USB drives and headphones etc..
I will probably mount it under my desk so a small square one would be nice.
Don't want to spend over $30
Smoking weed at the red light like its legal
https://linustechtips.com/topic/801470-usb-hub/
1 minute ago, VVoltor said:
Like this? https://www.amazon.co.uk/ONCHOICE-Switch-light-Cable-Length-x/dp/B01FHPVF6U
There's tons of them on Amazon really. I'd just go for one with good reviews and a design you like and you'll probably be fine.
Yeah but us not uk
https://linustechtips.com/topic/801470-usb-hub/#findComment-10078801
3 minutes ago, HunterSkater429 said:
Yeah but us not uk
here
https://www.amazon.com/Anker-Aluminum-Portable-Adapter-Devices/dp/B00PBZX0OM
or
https://www.amazon.com/Plugable-port-USB-3-0-hub/dp/B008ZGKWQI/
or just spend 5 minutes on Amazon or eBay or something
Does you mum know you're here?
https://linustechtips.com/topic/801470-usb-hub/#findComment-10078809
I'd recommend any Anker USB hub. I have five of them, (different models) and they all work great, and they're reasonably priced. Personally, I prefer the black theme, so I would pick this one: https://www.amazon.com/gp/product/B014ZQ07NE/
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/801470-usb-hub/#findComment-10081872
