Hey everyone,
I have upgraided my pc a long time ago with some new ram. I went from 2x2 GB to 2x4 GB. Today i opend a program were i could see my pc specs and i saw that my ram had a max bandwidth of 666.7 MHz and on the site i bought them they say it runs on 1600 MHz. How is this possible?
I did check my bios if i could change it there but i was not abel to change any thing.
my pc's specs:
Mobo: Msi 870a-g54
CPU: AMD Athlon II x4 640
Memory: Corsair Value Select CMV8GX3M2A1600C11 DDR3
(I know its outdated but money problems)
does anyone know how to fix this problem?
thanks for help.
(sorry if my English is bad that's becaus iam 15 years and dutch)59553812bb9cb_ramprobleem.thumb.png.f0cf9b24b74c3ee1792beb29fa49e168.png
https://linustechtips.com/topic/800457-ram-speed/
The motherboard you have supports 1600MHz only when overclocking the ram. Highest it will go without overclocking is 1333, which is the speed your is running at currently.
DDR stands for Double Data Rate (synchronous dynamic random-access memory). The number you're seeing in the Control Center needs to be doubled to get the frequency at which your memory is currently running.
More info on ram on wikipedia
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/800457-ram-speed/#findComment-10067918
It's running at the default speed of 1333MHz. Since DDR means double data rate, 667 x 2 will give you that number.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/800457-ram-speed/#findComment-10067921
Just now, TinyBuxTom said:
Your CPU can't handle  more than 666.7 mhz. So that's why you stuck on this number and can't get higher. If you want to get the actual RAM speed you need a better CPU and maybe a better Motherboard.
Incorrect. read the above answers.
https://linustechtips.com/topic/800457-ram-speed/#findComment-10067935
