12 minutes ago, YooNiCurn said:
Network adapter is enabled. no luck still sadly
Did you try updating the drivers with Intel's driver update utility? Sometimes the windows one can be a little wonky. Also another thing to check (yes I know it sounds stupid) the computer isn't on airplane mode or anything right?
https://linustechtips.com/topic/800034-help/#findComment-10063743
