System feels sluggish
Go to solution Solved by Zando_,
Run a malware scan and update all your drivers.
Hello everybody!
So since some time my PC feels so sluggish ...
Many programs need way too long to start, Windows explorer takes forever sometimes to open file directories.
I just want a fast experience when I am using my PC !
My Hardware shouldn't be the problem, I hope:
OS: Windows 10 latest Update
CPU: i7-6700K @ 4,7 GHz
MB: Asus Maximus VIII Formula
C drive: Samsung 960 Pro 1 TB
D drive: 2 x Samsung 950 Pro 1 TB in Raid0
gfx cards: 2 x 1080 Ti (Asus FE)
Last new windows installation ~2 weeks ago
Edited by TomSerious
https://linustechtips.com/topic/799964-system-feels-sluggish/
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/799964-system-feels-sluggish/#findComment-10062750
well, you have ssds so its not the drive speed. could be a corrupted OS. If it is truly windows xp level slow you might want to format the c drive and reinstall windows after pulling off all important files. If its only a little slow than I would just chalk it up to windows programs adjusting to the windows update.
https://linustechtips.com/topic/799964-system-feels-sluggish/#findComment-10062768
okay thanks! Could be the windows update thing, I did a fresh install like 2 weeks ago!
Additionally, could it be my overclock?
I remember a few years back, you had to increase the VCCIO (or whatever ^^) voltage too and do some fine tuning.
But I kept it fairly low with 4,7 GHz
https://linustechtips.com/topic/799964-system-feels-sluggish/#findComment-10062791
If the overclock is unstable it could cause problems. Perhaps you should dial it back a bit to see if it fixes the problem.
https://linustechtips.com/topic/799964-system-feels-sluggish/#findComment-10062803
