Hi!
So my computer won´t boot. When i press the start button the fans com on and the lights turns on an everything but it won´t boot.
What happened was that i was watching tv so i thought i turn the computer of, as i did so the computer shut down all programs and was shutting downs so i went away, when i came back an hour later rhe computer was still running, the screens were black and everything but it was stuck i guess, so i let it run for another two hours until i manually shut it down by pressing the start button. when i was going to start i again it didn't boot and 00 was displayed in the debug code. Now similar things have happened before so i did what i usualy do and unplug and start it again but it doesn't work, ive now tried to unpugg all cables with no luck. I built the computer myself so i might have put a cable in wrong or something and that might have triggered it.
I wonder what the problem is and what i can do about it, i've heard it might be the CPU but i wasn't sure.?
Thanks for answering and sorry for bad english.
Specs is in the photo!
https://linustechtips.com/topic/799933-msi-code-00-please-help/
12 minutes ago, Its Not Important said:
Check if your EPS power is connected properly or Check if there is any bent pins on your MOBO
i have checked for bent pins on all connections and havent foun any, and i have checked what i think is the EPS power and it is connected
https://linustechtips.com/topic/799933-msi-code-00-please-help/#findComment-10062428
Apparently there is no such thing as "00" it is supposed to be "D0" which means "Late CPU Utilization" (whatever that means)
Is the EPS connected properly? Seems like D0 error is quite common for this board
Try this:
https://www.google.co.id/url?sa=t&source=web&rct=j&url=http://www.tomshardware.com/answers/id-2889354/post-code-issues-code-msi-board.html&ved=0ahUKEwjXh-mnjOHUAhVJO48KHfEKCH4QFggrMAQ&usg=AFQjCNEPBJfM9WZ8-W3XHIR5zi7D19wpig
Seems to be working for some people, if not than RMA it.
https://linustechtips.com/topic/799933-msi-code-00-please-help/#findComment-10062438
Try this:
Ok thanks! I Will try it
https://linustechtips.com/topic/799933-msi-code-00-please-help/#findComment-10062494
