If your case is man enough for it, the Cryorig H5 is a worthy step up from the H7. Lands within a few degrees of the NH-D15, and the heatsink is thick enough that it actually benefits from push-pull if you pick up a second fan.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
im not sure how to check the dimensions. i have the deepcool kendomen. do you mind checking if it'll work??
case allows up to 160mm cooler, the H5 is 160mm+ depending on how you position the fans. tall ram may force you to have only 1 fan on it
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
40 minutes ago, Dylank12277 said:
is this a relatively quiet cooler?? i mean i understand that all of them will not be too quiet but i want a more silent one.
it should be quiet enough
it is also 149mm so even if you have tall ram heatspreaders it can still fit in your case
 i have some pretty cheap ram that i really dont know the name of and im pretty sure its not that big
The H5 is 160mm, taller if you raise the fan.
@Dylank12277, you could also mount the H5 Ultimate as a pull fan, but if it's already at the limit and you have high-profile RAM (standard or low-profile RAM will fit beneath it), something other than the H5 Ultimate is needed. The H5 Universal is designed for total RAM clearance and is a solid option as well, but there are plenty of other coolers out there that don't have this issue. I'm partial to the H5 as a price/performance leader.
if you're talking about those bare green ram modules you should have no problem fitting any cooler 160mm or lower
