Does 10-Bit Color Need a Compatible GPU?
Yes, and a compatible display interface (i.e. DisplayPort) as well as work with content programmed in 10-bit colors.
YES! You need also need a 10 bit panel like asus pro art panels!
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
This.^
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
That's what I was looking at, maybe a PA279Q
Just assuming because of your name, but if you're getting it for gaming, no games are programmed in 10-bit colors, so they will just look odd when stretched on a wider color gamut than they were designed for, unless you set the monitor to sRGB mode like a standard monitor, which would defeat the purpose of spending the extra money on the professional one.
