I just clean installed me system on new SSD and drivers and all
I turned on the HW Monitor to see if all is fine and it's reporting this
http://prntscr.com/forwao
I have no idea what i'm reading here on Temps
In one second it says low 40's in other second it shows 60's in the third second shows 50's? What the hell is going on?
When I start core temp it says driver not found? And I downloaded everything latest.
Also my CPU max freq is 4.1 Ghz base clock.
It like never goes beyond 3 Ghz, with or without load.
Anyone knows possible solutions?
I have latest version of BIOS aswell.
Challenger Tier at League of Legends since Season 5.
https://linustechtips.com/topic/799342-what-are-these-temps/
Current - Minimum - Maximum
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/799342-what-are-these-temps/#findComment-10055962
I know, I'm talking about "Current"
One second it's 50c, the other it's 40 the third it's 60?
That can't be true, temps can't jump like that.
I replaced the paste few hours ago Arctic MX-2
https://linustechtips.com/topic/799342-what-are-these-temps/#findComment-10055968
It can, kind of. Rebound the cooler, from experience this usually means not enough contact with the CPU
https://linustechtips.com/topic/799342-what-are-these-temps/#findComment-10055971
Cooler is fixed+ I have maximum airflow and chassie fan blowing on VRM+ it's not overclocked even.
https://linustechtips.com/topic/799342-what-are-these-temps/#findComment-10055977
Make sure you have the CPU fan connected to the "CPU_FAN" header on your motherboard.
I had a client with same issue on apu. Never going to max clock and high temps. His cpu cooler was on "Chassy_Fan" header. It's quick and easy to do, you can even do it with the pc turned on.
cheers!
https://linustechtips.com/topic/799342-what-are-these-temps/#findComment-10056461
