on skype you can call phones but you have to buy credits and stuff like that
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/79931-voip-system/#findComment-1095951
You can't do that without buying a VOIP software and hardware that are normally used in telecommunication companies that are able to send the voice traffic ( the phone call you are trying to make) to a something that can route it to the land line. :)
https://linustechtips.com/topic/79931-voip-system/#findComment-1096086
i know but what hardware should i buy
https://linustechtips.com/topic/79931-voip-system/#findComment-1096113
