Hi guys, So this is more of an asking for clarification post rather than a build critique or assessment.
I'm planning on making a new build soon but I wanted to use some RGB accented components. However, it seems that most of the software to configure the lighting on said components are proprietary to the motherboard or component manufacturer (think of ASUS aura, MSI mystic light, NZXT CAM). Seeing as I'd rather keep all of my RGB configurations specific to one software. Is there any software that can allow me to configure different RGB components from different manufacturers within one interface or do I have to try to make sure all of my RGB components stay within the support any one of those previously listed Softwares (MSI mobo w/ MSI graphics card, etc).
https://linustechtips.com/topic/799157-rgb-controller-options/
I don't know of any specific software, but I did watch a video from Paul's hardware a while back where he talked about making or buying adapters between brands, because they are basically the same, just have one or two pins a different way round. So if you found the software that you like best that can interact with hardware, and adapt the physical ports the brands or common strips of your choice. Gigabyte or MSI would be good bets for software that can customize the GPU, MOBO and other RGB components because they make all of the above and you can use that as a base to adapt from if necessary.
Sorry that wasn't all that specific. :(
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053923
I think Gigabyte is pretty good, and some of their mobos let you reassign the RGB/RGB-W pins, to avoid needing an adapter.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053957
That's cool!
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053962
Just now, SamuelJE said:
That's cool!
Yeah. I think it's on the higher end Aorus boards. I'm pretty sure it's on the X370 K7 and K5, but you could check.
Mouse: EVGA X17
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053968
Well there you go. That sounds like a really good option.
And because it's gigabyte it will also support RGB on their own brand of GPUs.
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053972
And Gigabyte makes some pretty nice graphics cards as well...
Mouse: EVGA X17
https://linustechtips.com/topic/799157-rgb-controller-options/#findComment-10053977
