Posted March 25, 2013 hey i am planing on buying a gigabyte ga-990fxa-ud7 mobo but jw would it work in my corsair 400r case the mobo i think is a e-atx. and the 400R says Motherboard Compatibility Micro ATX / ATX Link to comment https://linustechtips.com/topic/7990-lil-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 It depends, some eATX boards fit, some don't, some of them are only an inch wider, but yet again, I wouldn't risk it. But if Corsair says mATX and ATX, I wouldn't want to try sticking an eATX board into the case. Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat, GTA 5 LTT Crew at LTT Conglomarate PC Specs - 4770k - OC 4.5GHz - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 - Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89539 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Author It depends, some eATX boards fit, some don't, some of them are only an inch wider, but yet again, I wouldn't risk it.But if Corsair says mATX and ATX, I wouldn't want to try sticking an eATX board into the case. then i guess all get a new case then i like the mobo so Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89544 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Author wait the mobo on a web site says its a Form FactorExtended ATX Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89546 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Author this is the mobo http://www.gigabyte.us/products/product-page.aspx?pid=3880#ov Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89548 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Don't expect it to fit as it clearly states it is E-ATX and Corsair have only given compatibility up to ATX size. Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89605 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Author Don't expect it to fit as it clearly states it is E-ATX and Corsair have only given compatibility up to ATX size.what about in a corsair 900d when it comes out Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89607 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 25, 2013 Yes a 900D would be able to accommodate that board. Link to comment https://linustechtips.com/topic/7990-lil-help/#findComment-89870 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
