I need an 1150 socket board in mini-itx form factor that either has onboard wifi or supports a half-mini wifi card. Doesnt need to be overclockable. Cheap as possible please. EDIT: The big issue iove run into is they're all out of stock, so please take that into consideration when looking
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/798972-motherboard-selection-advice/
where are you located? So wee can check the prices in your country
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
'Murica motherfuckers :P
