hey guys a friend of mine said i should post a topic in here. if i want better answer what kind of headset to use
i was looking at -  Logitech G933 Snow Edt. Gaming Headset
but my friend said that one keept dying all the time for him and it was a bad one
 so i joined here to seek info what kind of headset i should get
https://linustechtips.com/topic/798964-seek-some-help-with-wireless-headset/
The G933 is worth every penny in my opinion. (I own one) Your friends headset is dying all the time probably because he has some crazy lighting effect. The G933 gives you a 12-13 hour battery life with no lighting effects. It can also be used as a wired headset through the included 2.3 meter charging cable or a 3.5mm audio jack without your EQ and all that. Also you can save your EQ and lighting profiles directly on the headset memory. and you can cycle through them on the go as long as the heatset is powered on. The G933 also has amazing sound out of the box, but you can adjust it.
TL;DR: Great headset, 12hr battery life with no lighting, worth every penny, save settings on the headset.
IF you are going to spend money on a headset at that pricepoint I would highly recommend dealing with the wires and going with a Sennheiser game zero:
https://www.amazon.com/Sennheiser-GAME-ZERO-Gaming-Headset/dp/B00GWU8FAE?th=1
Superior Sound stage; superior mic; Sennheiser brand
Don't forget to quote me (or someone else), otherwise we aren't going to receive your answers...
~Jano
2 hours ago, ItsTheDuckAgain said:
a non wireless one because everything half price is better than that.
Have a look at Beyerdynamic Custom one (not pro) + modmic - just google those :-)
just my 2 cents - start hateing me now :-)
no hate here :D just info i need to decide what kind of headset i need :P
yea im thinking of g933 but wanna see if there is any better one
a other friend of mine had the old version but he did get the charge issue when he plugs it in
money atm is no issue xD planing of getting a new mouse , keyboard as well
im using ASUS ROG Vulcan Pro  atm like it alot just cable issue so thats why i seek a good one wireless ;D
i already switched out my other Vulcan to a new one because it got stuck with my chair so the Cable / volume box thing broke xD so they gave me a new one
Im going to second I own a G930 and have no complaints
